This command configures the remote-id option as described in RFC-4649 to an IPv6 BOOTP relay/DHCP relay agent.
| bootprelay | BOOTP Relay Service |
| ipv6 | DHCPv6 BOOTP Relay Service |
| option | DHCPv6 BOOTP Relay options |
| remote-id | Remote-ID sub-option to identify remote host |
| remote_id_string | Remote ID String |
| system-name | System Name string |
| none | Identifier defaults System MAC address |
| all | All VLANs |
System MAC address if not configured.
Use this command to configure the remote-id option as described in RFC-4649 to an IPv6 BOOTP relay/DHCP relay agent. After receiving an IPv6 BOOTP/DHCP request packet on the specified VLAN, the agent adds the configured identifier to the packet and passes it to the server. If this option is configured to be as system-name, the switch name is used as the remote-id. The same can be unconfigured using the none option. After unconfiguring this option, the switch MAC address (the default value), is used as remote-id. This option can be configured orunconfigured to a specified VLAN or to all VLANs.
* Switch # show bootprelay ipv6
BOOTP Relay: DHCPv6 BOOTP Relay enabled on virtual router "VR-Default"
    BOOTP Relay Servers : 2001:0db8:85a3:0000:0000:8a2e:0370:7334
                          2001:0db8:85a3:0000:0000:8a2e:0370:7335
                          2001:0db8:85a3:0000:0000:8a2e:0370:7336
                          2001:0db8:85a3:0000:0000:8a2e:0370:7337
VLAN "Default":
    BOOTP Relay         : Disabled
VLAN "v1":
    BOOTP Relay         : Enabled
    Interface ID        : v1-12
    Remote ID           : v1_remId
VLAN "v2":
    Interface ID        : 100 (Default)
    Remote ID           : 00:04:96:52:A7:1B (Default)
    This command was first available in ExtremeXOS 15.5.
